U4GM Where to Find Hip Fire and ADS Accuracy Stats In Game
Klubo narių organizuojami grupiniai pirkimai.
Standartinė Rodrigo60 » 2026 Kov 19 12:31
Four months in, I'm still surprised how often this game makes me swap between feeling like a genius and getting folded in five seconds. It's got that "they actually fixed it" vibe—classes matter again, the map breaks in ways that change how fights happen, and squads finally feel like squads instead of four strangers sharing a spawn point. If you're grinding hard and just want to test stuff without the usual chaos, some folks even hop into a Battlefield 6 Bot Lobby to get clean reads on recoil, gadgets, and routes, and honestly I get why.
Patch 1.1.3.6 quietly changed the vibe
Since late January 2026, patch 1.1.3.6 did the obvious stuff—movement feels less sticky, and the random desktop crashes aren't haunting every long session. But the real twist was the post-match reporting glow-up. The accuracy split into hip-fire and ADS looks small on paper, yet it instantly tells you why a setup feels "off." Like, you think your aim's trash, but it's actually your hip-fire bloom, or you're over-scoping in tight rooms. Season 2 sliding to mid-February didn't bother me either. Frostfire running longer meant I could mess around and learn without that battle pass panic.
Finding your stats is actually painless
This part shocked me: it's not buried. From the main lobby, your player card's right there on the top bar. Tab to Profile and you get the headline numbers straight away—K/D, win/loss, SPM, revives, objective captures. Then it breaks out by class, weapons, and even gadget usage, which is where you start seeing bad habits you didn't know you had. Load times are basically instant on a PS5 or a decent PC, and even on a Series S it's like a quick blink. You leave a match, open the menu, and your latest round is already baked into the totals.
Progression is where the nerdy stuff lives
Hit the Progression tab and it gets properly granular. You can filter down to one weapon and check headshot rate, range performance, and that hip-fire vs ADS split. Specialist stats are there too, and they're humbling—seeing your "healing" number with Falck can be a wake-up call if you've been pretending you're support while chasing kills. Vehicle tracking is split by air, land, and sea, and you can compare modes, which is great for spotting what's actually working versus what just felt good in one lucky lobby.
Using the numbers without getting lost in them
I did a little experiment over ten Conquest rounds on the Orbital remake, just to see if the game was making things up. Assault kit, M5A3, short barrel, and I tracked hip-fire the hard way. The report matched: 37.2% hip-fire accuracy across 842 rounds. When it's that specific, you stop arguing with vibes and start tuning builds with a purpose. And if you're short on time but still want your profile to reflect what you can actually do, I can see why people look into Cheap Battlefield 6 Boosting as a way to catch up while keeping their loadouts and stats pointed in the right direction. You can learn more now from u4gm.
Rodrigo60
Pranešimai: 4
Užsiregistravo: 2026 Kov 19 09:59
Grįžti į Grupiniai pirkimai
